22re Fuel Cell ?'s
StretchASU
Creedmoor, NC/Claudville, VA
Gathering info and wanted to see what setups have worked well for you guys in the past. I've always done pane on 22r's so I've never messed with the fuel cell stuff.
What cell did you use? Maybe a part number if you have it
How did you plumb the pickup? Just one line coming out of the bottom of the cell, if the cell had 2 fittings for pickups did you T them together etc?
How did you plumb in the return line? Top of cell?
Did you vent it back to the charcoal canister or just put a hose and filter on the vent line?
What pump setup did you use?
What fuel cell are you looking to get?
usually they have the AN fittings for pickup, return and vent. I was planning on venting to the charcoal canister when i convert back to a fuel cell.
I haven't decided on what cell yet. Probably just an RCI/Jegs/Summit plastic cell with some foam in it. Seems like thats the popular one to use and everyone uses either an 83 celica inline pump or an E2000. Just figured I would throw this up here to see what some people a little more local and smarter than me have used with good results and collect some ideas before buying parts.
At least the way I have it in my head is a 8-12gal plastic cell with one -AN fitting low on one side of the cell for the pickup. AN to barbed fitting and some fuel line to mount the external pump below and as close to the cell as possible so it doesn't have to strain to draw fuel up out of the cell or far from the cell. Then on top have 2 AN fittings that I would run an AN 90* fitting to a barbed fitting and just reconnect the return and vent lines to whats already run under the rig from the factory.
