92illpony
- Jun 6, 2005
- Dalton, Ga
Pulled the body lift on my truck and i think i know the problem but the way it started i'm confused. My truck has a drivetrain lift and exhaust runs really high also. I pulled the bodylift and drove the truck down the street and noticed some exhaust issues so i jacked up one side and pulled out a heat shield and that seemed to fix the problem. Went to test drive it and made it about half a mile and stopped at the stop sign and when i went to take off it bogged down and died. Repeated this 4 times and then pushed it out of the street. Truck would start for 2 seconds or so and shut off. After a few attempts it finally wouldn't start. Its really dark out and my truck is half mile away. I Checked fuel lines and all appear in good condition. I did notice that my oxygen sensor wires were pushed into the body pretty good and i think this is a good portion of my problem. My EFI fuse i think it is is popping and i'd say its from grounding out. If this is the case why did it do the run die deal over and over if its grounding out and blowing the fuse?
thanks in advance.
thanks in advance.
