I put one of Thea obx 2.5'' header kit on my truck it bolted up fine and sounds good except for there's a factory drilled hole right in the middle of it on the bar that goes across the bottom of the manifold between the bottom 2 bolts
00_00 it would be in the middle of the underscore here, exhaust is comming out, on a factory manifold there's no hole there it's just solid across, just wondering if anyone else has seen this and what they've done to fix it or if I could just weld it shut any info would be greatly appreciated
