lwpruitt New Member Joined Sep 25, 2012 Sep 25, 2012 #1 I ahve a oil leak at the back of my engine above the tanny, it a square box ,do any of you know whats thats call or how to fix it thanks
CTRaceWorx Well-Known Member Joined Aug 23, 2007 Location Charlotte Sep 25, 2012 #2 The only square thing that I remember back there is the EGR plate, unless its leaking from a half moon or head gasket
lwpruitt New Member Joined Sep 25, 2012 Sep 25, 2012 #3 that square box has a black hose going to it ,but it may be coming from V C thanks I will check again
cgm147 Well-Known Member Joined Feb 23, 2008 Location salisbury Sep 27, 2012 #4 i have the same problem and i cant stand it.. makes a hella mess on the trans sent from deep space via galaxy S 2
Jweezy DD/Hauler(kids,groceries) Joined Feb 2, 2009 Location Kannapolis NC Sep 27, 2012 #5 hum thought it was just a yota thing....
BrianGreen SSG Brian Green Joined Apr 5, 2008 Location Kings Mountain Sep 28, 2012 #6 I would bet that it is one of the half moon seals. Pull the valve cover and replace the half moons and VC oring.
Chris_Keziah Joe Dirt @ Rev Limit Fab Joined Dec 1, 2010 Location Winston-Salem Sep 28, 2012 #7 sgtbriangreen said: I would bet that it is one of the half moon seals. Pull the valve cover and replace the half moons and VC oring. Click to expand... X2 just make sure to hold the rear one in. I've had them push out while puttin the vc back on. Sent from my smart box using Tapatalk
NCJeyota Well-Known Member Joined Jun 1, 2009 Location Raleigh Sep 28, 2012 #8 That black box I think you're referring to is a coolant bypass (circled in red) but the half-moon plug is right above it and may make it look like its leaking.
RatLabGuy You look like a monkey and smell like one too Joined May 18, 2005 Location Churchville, MD Oct 1, 2012 #9 ^^ thats my money too. Notorious for leaking. While you have the cover off, check the valve lash to make it worth your while ;-)
