22re to 22r
dmfh1272
Member
wnc
I would like to know what is required to convert a 22re to a carb setup? I know the intake manifold will swap over but what about the electrical? Do i need to swap distributor or.anyhing any wiring changes?
You will need a carb distributor. You can use the ignition/coil that was there, but I went with GM ignition/coil.
Good thread on pirate....I'll see if I can find it...
Thank you i googled it and found some things on pirate but nothing detailed
i did the same thing to my 22re to 22r on propane. got a carb intake manifold and carb distributor . but im running mine off a msd box.
