242 Transfer Case Linkage Question
LBjpXj
Clayton/Raleigh
2001 XJ 3.5" lift, 242 case. I just put a rustys 1" drop trans xmember on and now I cannot get the transfer case past 4full-time and cannot get into low, I know its w/ the linkage but nothing seems to be bent or has popd out of place. Any advice appreciated Thanx
You need to adjust the linkage it has a bolt that holds the linkage rod. It should.be on the driver side. Get someone to wiggle your tranfer case shifter so you can find it.
