andrewlail76
- Jun 21, 2006
- Hickory, NC
How much air do I need to run in the 245/75 R16s that are on it?
Is it more than the standard 30s in a car?
It should say on the side.
I won't have a load of more than 6 people (4 adults and 2 small children) and a little luggage.
45-60 is a broad range
You have this size tire? Stock on it are supposed to be 235/85 R16
Anyone else?
I figure the max for the best fuel economy...
The decal refers to original tires from the factory. evry tire is different. The best advise is to contact the tire manufacturer and ask one of the tech guys. That is how I got the 45-60 psi range for my tires.isn't there a decal on the driver's side door jamb that specs the stock tire size and recommended inflation?
You left out a little tidbit of info that's a wee bit important. LOAD RANGE.
60 is probably OK if you're not towing.
but why would the stickers (OE) have 2 different sets of pressures?
