RatLabGuy
- May 18, 2005
- Churchville, MD
Just learning my way around a 302 (in an old Bronco).
What would cause this (see pic) - rocker slid off to the side to the top of the valve wasn't on the roller on the end of the rocker?
I tapped it gently and it popped back into place.
I'm assuming this means needing a valve adjustment and making sure the nuts are tight?
Fun part... I know know nothing about whats in this motor, except that the idle is pretty "lopey", and the heads are Eddlebrocks so I really doubt it is a stock cam.
Its never run well since I've had it so I have no experience to work on.
