Eli05
- Oct 11, 2008
- Canton, NC
I have a 73 Bronco with a 302 and can get a good deal on a C6 from a 78 F-150. What would I need to do to bolt these together.
The c4 is plenty strong and the c6 will only add weight and suck (much) more power.
QUOTE]
I couldnt have said it better, DONT DO IT
QUOTE]
yep. you can find c4's easily anyways and build them or just get an AOD if its street friendly.Do you have a stock 302? Is the bronco trans working fine at the moment? Don't do it either way. The c4 is plenty strong and the c6 will only add weight and suck (much) more power.
Otherwise, what he's saying is true...it probably won't work anyway.
