- Mar 10, 2005
- Hooterville (24171)
I've already acquired the major bits (still waiting on a few small items) needed for transplanting a GM TBI on top of the 304... and already started the dismantle of the old bits (carb, ignition, etc.). My engine was a reported rebuild some 5 years ago w/ rebuilt heads (NO port work), OEM ex. manifolds, decent oil pressure & compression. Overall, it ran pretty dang good with the 2100. The TB will sit on a homemade 3/4" AL adapter on the stock 2bbl intake and be fired with a "de-mechanically advanced" DuraSpark dizzy thru the GM ignition module & TFI coil.
In an attempt to kill 2 birds, the exhaust needs work! Since my booty fab 2.25" duals (clearance issues constantly causing sealing issues) are toast *AND* I'll need at least one O2 bung in the pass. side... was exploring alternatives.
LoMod has offered up a recent exhaust (minor surface rust, but very good shape) from his project EV Commando, which should be bolt-in. It's 2" from each ex. manifold into a single 2" back to a generic "Flowmaster looking" muffler with tailpipe over the rear axle that exits the rear. The only potential things I can see doing... reworking the "Y" junction (pass. side looks simply butted into the drivers side tube) and depending on clearance/fit, cut the rear to exit out the side/corner... and of course O2 bung(s). Appears it should tuck up into the frame nicely = less chance of getting mashed/ripped by terrain than the current setup.
From what little I can find online (various sources/calcs), the 2" exhaust is optimal for a stock 304 operating under 4000RPM (much more... the valves float ).
My main concern is negating the increased air flow from the TB (approx. 500ish CFM) compared to the 1.08" 2100 (approx. 350CFM).
Looking for thoughts/opinions WITH data/reasoning to backup your response...
