Rox&Mud
CTB
- Nov 3, 2006
- Rocky Mount
I have been having some intermittent engine issues that only seem to occur while wheeling. It will start to run rough and may even stall out then it's hard to start if it even does. I have not been able to reproduce the symptoms except on the trail.
That said, I just checked the pressure again and have a question.
According the Haynes it should have 44-54 psi with the key on, running or not. With just the key on it goes up to 47 psi for about a second then immediately starts dropping back to about 10/15 psi, is this normal? If not any ideas? Also while running at idle and at normal operating temp the needle on the gauge starts to shake until I give it a touch of throttle then it evens out.
Any thought you guys have would be helpful chasing down this gremlin w/out just throwing parts at it.
Thanks
Thanks
