I'm swapping a 4.0 from 92 xj into the 87 yj. I pulled the entire harness out of the xj with the motor. We set the 4.0 down in the yj this past weekend and everything was going fine. We starting hooking up all connections and loose ends, PDC and computer all are there. The trouble arises in the ignition. We still can't seem to get the harness's spliced so that it'll start off the key. So far the only way it will start is by jumping it from the battery to the starter wire, and even then it will only run for a few seconds. Were getting fuel to the motor and all, just can't seem to get it to start. Also there are still a few loose connections that haven't been connected. Believe me I've tried, along with the help of others, and we still haven't found where they go. To me, this lies as a variable in the ignition problem. Without all the connections being plugged in, its hard to determine the exact cause of the problem. However, this is my first swap and its all pretty intimidating, but basically all thats holding it back from running is the ignition. Alot of the stuff that isn't connected is most likely irrelevant, but I'm not running the wipers, AC, heater, horn, fan, yada yada off the xj. Anyways, does anybody have an insight on what could be going on? TIA!!!
Austin
Austin
