AX(J)15_tudor
- Aug 5, 2012
- Harrisburg
Lots of posts on the www on this but wanted to see what the NC 4x4 consensus was. I just replaced the oil in a TJ with 4.0 I just purchased. The oil in it was pretty old and black I used Rotella 10-30 partial synthetic and a mopar filter. Shortly after a tick started. I haven't driven it enough to know if it goes away after running a while but it's noticeable. It seems mainly to be coming from the passenger side. I need to check the manifold for a crack and listen around to see if it's maybe external.
If it was a lifter though what would you guys recommend? Below is a checklist of things I've seen on the web. I know from owning an XJ with 240K on the clock these suckers are noisy but it being a new purchase of course my ears are more sensitive. Power seems good other than what the vampire 42rle sucks out.
In various combinations:
Use Seafoam through TB or crankcase and change oil
Use Seafoam through gas tank
Use rotella 15-40
Drain the oil filter and add equal amount of MMO - run 500 miles, rinse repeat
eff it till it stops running
Use rotella 15-40
