Most of you know that I've been having alot of trouble out of my 4.0 since Fall Crawl. I'll save the story and get on with the tech.
I have installed NEW:
Rotor button
Dizzy cap
Air Filter
Fuel Filter
Plug Wires
Plugs (first set was bosch platinum they fouled out, so installed NGKs)
Now, I'm getting fuel at the rail, and it is cycling back to the tank as it should. I'm running an e2000 as I have been for about 2 years. Its working fine. I have spark, and a full tank of fuel.
The motor is a 92 4.0ho out of an xj that I swapped into my yj. It has been running like a top for the past 2 years, never had any trouble. I'm 99.999999% its my wiring. I kept the original harness from the xj and paid/worked with a guy who helped me strip it down to the essentials.
I ran it this way for around year and a half. No trouble. One day my stock gauges decided to quit working completely, lights would cut out etc. Stripped all that mess out, built new dash yada yada. I now have 5 gauges, some switches, and some other stuff. The rig is pretty much bare bones when it comes to wiring. I just can't figure out why it won't run.
Sometimes I'll walk out to the garage it will crank first try and run. Other times it won't crank for a whole week. If it does crank it will run for around 15 minutes then just quit. Other times it runs for 1 minute and will quit. It fired this afternoon so I drove it around the parking lot and then let it run for around 10 minutes in the garage, ran great. Then I backed it out for a second to move some stuff around and it cut off. Wouldn't crank back for around 2 hours. Then it just fired right up and I pulled it in.
Maybe its a sensor? Some people have mentioned CPS, and auto shutdown relay. I don't think its the CPS as it will fire and run fine at times but who knows? Also, I have no auto shut down relay as the guy I paid to wire it stripped everything out. I have the xj computer running the motor and none of the other stock stuff.
SO anyone got any ideas?
Rotor button
Dizzy cap
Air Filter
Fuel Filter
Plug Wires
let us know how it goes man
