YJJPWrangler
- Jul 19, 2005
- Charlotte
I am getting ready to get the drivetrain together for the Willys. However, I need some help.
I have a 1991 4.3L. Its being mated to a SM420/D300. I still need to order the clutch/pressure plate/pilot/throwout/hydro slave. I have a flywheel that needs to be machined/resurfaced.
The problem is this. The flywheel was off the motor when I got it, the distributor was off as well. I have hand rotated the motor more times than I can count. I have seen that prior to removal, the flywheel should be marked so that exact location can be installed again. Obviously this did not happen. Same issue with the distro. I'm assuming that I can set the motor to TDC on cyl 1 and then install the distro correct? Does it matter how the flywheel is bolted back up?
Any advice/tips for this?
Thanks,
Thanks,
