- Jan 3, 2015
- Boone NC
tranny threw bunch of codes....2 were fluid pressure codes, gear 3 ratio incorrect, gear 4 ratio incorrect, and gear 1 ratio incorrect....customer brought me a New Solenoid Pack that mounts up on top of valve body after he did his research and said this would fix it so i looked into it and seemed to be the common culprit. I'm not a tranny guy mind you, I installed it and now it won't do anything??? before it would go in R but slowly and sluggish and wouldn't go past 1st and you could tell it was a pressure issue but now with new solenoid pack and new fluid and such, nothing? anyone have any experience with these trannys and got any advise. the install was pretty straight forward so can't see anything gone wrong but is it possible the new solenoid pack is bad or am i missing something....and does this 45 RFE tranny have a Governor pressure solenoid separate or is it part of that solenoid pack...that's the only code it's thrown now with new part just from idleing and shifting through the gears up to operating temps....it threw a po841...pressure soleniod malfunction (something like that) any help would be really appreciated. thank u very much.
...live and learn i reckon. he installed both filters weeks ago and must not have seated that grommet all the way cause they don't just pop right out and i've always had to use a socket to tap them into the housing a bit. thank you for your help and advise guys. have a blessed weekend!
