paradisePWoffrd
Recovering Project Junkie
- Nov 5, 2005
- Newton, NC
I finally got my wiring issue figured out, but am running into what I think is a fuel problem...
What I have:
Suzuki 1.6l 8v w/ carb intake
CA100 mixer
JB-2 regulator
VFF30 lockoff
Issue:
It will crank up and run, but will only stay running for a minute or so. If you put your hand over the air intake it will run a little better, but will still cut off. If you give it any throttle at all it will start to rev and then die.
I have tried adjusting the mixture screw on the mixer and timing of the distributor, and it will change the way it runs some, but still dies.
Im not sure what exactly is going wrong. Also if anyone knows if there's a way to adjust the mixture at idle & speed, or is it just the one next to the intake port.
What I have:
CA100 mixer
JB-2 regulator
VFF30 lockoff
Issue:
