Croatan_Kid
How's your hammer hangin'?
- Nov 4, 2007
- New Bern
I just did a full rebuild on a 4L60E for a buddy. He bought the truck from me and I had bought several parts which were included in the sale. The majority of which were transmission rebuild parts and a new torque converter. It was a "Monster in a Box" kit and the converter came from them as well.
Before the rebuild, it had burnt 3rd gear, wouldn't skip it and go to fourth. The band looked fine and so did all of the other clutch packs. Good enough.
I pulled it down, cleaned the hell out of everything, replaced most of the soft parts (seals, o rings, etc), it even got a new valve body! The Monster stuff comes with new sprags, the pump rebuild stuff, and all of the usual upgrade stuff. It all went together as well as I expected, just as they have in the past transmissions I have built. The only difference is this is the first 4L60E I have done, the rest have been 700R4s.
Long story short, filled the converter, put the trans back in the truck after an all-nighter, filled the pan, fired it up and kept adding accordingly. Moment of truth! The truck was on a lift, no tires on it, shifted through all the gears and they worked. So I let it run through the gears. I get up in to third. We throw the tires on it, drop it down and back out.
Once I put it in "D", it won't move. 3 and 2 are the same. I have Reverse and manual 1. I also read a PO748 with my HP Tuners VCM scanner. I tried to use that to command 1st, 2nd, and 3rd gears and nothing wanted to work. It would lock the converter clutch though. If I took off down the road I could get it to jump from 1st to 3rd, but that was it. That made me think it was a band or 2/4 servo problem, but it only works when I pull it down to 1. That would make me think it was a broken sprag, but I just replaced them and check their operation prior to installation.
Any ideas guys? I'm tired of driving 40 miles each way to work on this damn thing, it's really starting to kill my weekends, money, and at this point it's personal. I'm gunna kick this transmissions ass in to submission and it's going to like it. This thing should bark the tires on a WOT 1-2 shift.
It was a fuster cluck. I'm waiting on the "It works!" text and hopefully not the "get back over here" text.
