loose cannon Well-Known Member Joined Oct 1, 2007 Location MARION Mar 20, 2010 #1 I have a 95 burban 4x4 frist gear has came out. can i take a 2wd 4l80e swap the tail housing on my 4wd. will it work or what problems will i run in to
transman731 get your shift together Joined Mar 13, 2010 Location Raleigh, NC Mar 20, 2010 #2 no you can't just switch them, the output shafts are different. is that all that is gone, do you have manual low? if you have 2 and 3rd with no 4th, it is most likely a shift solenoid.
