russ0943
yehaw x10
- Mar 28, 2007
- Valdese, NC
2000 F250 7.3L 4x4 stock 200k; Trans rebuilt 60k ago.
OD light started flashing on me the other day and the trans went into limp mode, still drivable. The only code was P0741 (Torque Converter Clutch Cir Perf/Stuck Off).
I checked fluid level (fine). Changed fluid via correct procedure. No change.
I dropped the pan and removed the solenoid pack. Tested resistance between pins 1 & 4 with 13ohm (spec 10-20 ohm). Visually inspected wires and connector (fine). Buttoned it back up. No change.
Checked all fuses in cab and under hood with meter (fine).
There was an abundance of metal shavings on the magnet. Probably enough to fill up a coke bottle lid.
What I'm needing to know is: what are my next steps in troubleshooting this?
Symptoms:
When I shift into Gear the trans makes a whining noise. Shifting is fine with possibly a little slip until it goes into limp mode, then shifting becomes noticeably harder with the increased line pressure.
Thanks for the help.
I posted this on a diesel forum and got reply below. Looking for some added opinions.
*This code means there is converter slip when the PCM is commanding it to be locked. It is not an electrical code. That means there is no electrical problem, so you can eliminate all electrical checks. You won't (didn't!) learn anything doing electrical checks.
There are several things that can cause this problem. Most likely, especially with shavings present, is the torque converter clutch control valve in the valve body is stuck. Also possible are worn seals on the input shaft, or a bad torque converter.
Symptoms:
