SHINTON
- Mar 17, 2005
- Triad area of NC
Well, I am 90% sure I will just go watch the carnage instead of BEING the carnage, but it makes for interesting speculation to make the week go by faster, eh?
Class A: Street
Up to 33” tires
No lockers (factory posi ok if it is an option for your vehicle)
Stock suspension design (no longarms)
No extensive motor mods (i.e. strokers or nitrous) or motor swaps
So IF...you were gonna buy / build ya a beater for this or Class B...what makes the most sense? Budget being a consideration obviously....nice part is when you are done, you then have a beater to impress your neighbors with too!! BONUS!
I believe this is a SPEED competition, so shorter wheelbase might be more of a disadvantage because of handling?
XJs... biggest selling point is CHEAP, coil front already, and lift is not a problem just stock style. Put on some 6" springs on the front to soak up the bumps (think baja) and maybe bigger leafs on rear with axle still at same wheelbase.
Strip the interior, weld in a cage for safety (then you could remove windows for weight) Cut the fenders and WHEEL with Zeal on the 33s?
Or ZJs....and you get a v8 to start with...? Just a 'crappier' tcase/awd..and I figure this will be a mostly 4HIGH event..possibly 2HIGH most of the time with 4wd engaged only on the technical stuff?
Just figured this would be a fun topic for all, would love to see any threads in the photos area of folks building specifically for this?
Same exact vehicle except 'long arms and 35s' to soak up bumps even better and go with B class? Weld up the rear and manual a manual disco for the welded front for easier steering?
Class B: Modified Street
Up to 35” tires
Lockers ok (front and rear)
Stock suspension design (longarms ok)
No motor swaps
Class A: Street
Up to 33” tires
Up to 35” tires
No motor swaps
