While swapping out my 5.3 truck oil pan and pick up to an F-body style set up, I broke the bolt off in the oil pump that holds the pickup tube on. I thought I could cheat and dial my ft/lbs torque wrench down to 8.8 and it would be the same as the 106in/lbs. Mathematically, yes, real world, Ehh-ehh, WRONG-O.
-Doesn't begin to describe how pissed I was when it happened.
Seeing as how now is a perfect time to replace my oil pump, I was thinking of upgrading to a Melling high volume-high pressure unit #10296. This one comes with a low pressure optional spring to flow more volume, but at stock pressure. (I'm only @100K miles on the motor according to the seller)
I'd like to hear from guys who have had any experience on running a 10296 or comparable high flow pump. I have read maaaaany different opinions on all sorts of sites as to whether it will "suck the oil pan dry" or cause leaks, ect, but most have been from pavement racers, not those who put their motors in off camber situations.
I am considering using the high flow Melling with the "stock pressure" spring. Any thoughts?
Thanks for the help, I'd love to see you all at the ECORS DPG race. (as a spectator)
-Brandon Shore
-Doesn't begin to describe how pissed I was when it happened.Seeing as how now is a perfect time to replace my oil pump, I was thinking of upgrading to a Melling high volume-high pressure unit #10296. This one comes with a low pressure optional spring to flow more volume, but at stock pressure. (I'm only @100K miles on the motor according to the seller)
-Brandon Shore
