5.9 d44a axle swap
Charlotte
I am swaping rear axles on a 5.9 grand cherokee and it has a dana 44a with 3.73's in it. The rear end is blown. SINCE ITS A DAILY DRIVER!!. I found a 44a with 3.73's out of a 5.2 grand and ready to bolt right in. Is there any difference between axles I should know about before I do the swap. I noticed the pinion yokes are different and the 1 5/16 pinion nut was a biatch to take off and switch. Any advice or comments would be geat Thanks
did you get a new pinion nut? they are crimped and only meant to be used once
Also how did you torque the new nut down? To 230ft lbs or what?
Brendan
