- Mar 10, 2005
- Hooterville (24171)
2004 "late model" 6.0L... 108K
Recently deleted, new Ford oil cooler, rebuilt #1 injector, fresh oil (Rotella T6 5W40) & Motorcraft oil/fuel filters
Noticeable miss/extra clatter when cold... miss comes & goes when warm.
Repeated logged codes "Cyl.#7 balance & contribution" (cleared and will return).
Buzz & contribution tests with a Nemesis all passed...
No idea what the fuel pressure is, but do know the steel fuel tank (C&C) is de-laminating from debris found in the HFCM "primary" fuel filter (tank will be addressed come spring)... FP gauge & blue spring on the way
So, I've read & been warned that regular contribution tests won't necessarily pinpoint *bad* injectors due to the FICM compensation (basically good injectors being over-fueled/driven to compensate for a bad injector), so the ability to run a "non-compensated contribution" test is the best way.
Anyone local have a scanner with that ability?
Have also read that marginal FICMs will also cause sporadic missing, even if the voltage isn't in the 45V "danger zone" (mine runs 47.0V, with occasional dips to 46.5V-46.0V)??
Question for all the 6.0L gurus... where would you go first?
