family xj
- Feb 19, 2006
- Jacksonville NC
My truck started running rough when it was cold. I would be idling fine then act like it was missing for a split second and then go back to running fine. Almost like it shut off. It only does it when it's cold. Once it runs for 20 minutes it runs fine. I ran the codes and it said I had a bad cam sensor and a bad glow plug so I replaced the cam sensor and ran the codes again and nothing came up. Like I said it only does it when it's a cold engine after it gets hot it is fine, well every once and a while it will falter but it's not that noticeable. I know nothing about the diesel other than changeing oil and filters.
I was told that the glow plug only plays a part in it when starting it and that once it is running the glow plug isn't really a factor.
Anyone got any ideas. I am hoping it is nothing major but knowing my luck it will cost a lot of $. Thanks
Doug
Doug
