HAPPY
Mike B.
- Feb 21, 2010
- Granite Falls
I have another diesel issue, this time on Dads truck.
It's a 96 250 5 speed all stock with 155K. It has a intermittent misfire. It will start and idle fine. When you take off down the road, SOMETIMES it will miss for a mile or two and clear up, SOMETIMES it won't mis at all and SOMETIMES it will miss so bad it will just shut off.
Injectors will usually stop working all together right?
I tend to think it's the under valve cover harness. From fumbleing around on a few diesel forums that is my best guess/
Dad seems to think it's fuel related. I know there are pick up pumps in both tanks but isn't there a high pressure fuel pump also? I thought about the high pressure oil pump also.
If there is a high pressure fuel pump, is it electric or is it driven with the high pressure oil pump?
Any ideas? I'm completely stumped, how do you find the problem when it isn't consistant. I'm just looking for a good starting point. Dads on a fixed income and doesn't have a lot of money to throw into it.
