7" Round 51 Watt LED Light at Motobilt
motobilt
Dothan, AL
7" Black Round 51 Watt LED light Click here!
7" Red Round 51 Watt Led Light Click Here
ascontent_atl3_1.xx.fbcdn.net_hphotos_xfl1_v_t1.0_0_s552x414_1fa0165bcb83513c03e81659bcdd56723.jpg
This listing is for one 51w high output LED light. Toughest design in the market designed for extreme conditions. Comes with 1 year warranty. Extremely bright even in daylight . Great for off road vehicles, trucks, atv's, utv's, construction vehicles, farm vehicles and trucks. Spot beam, heavy duty metal housing is water and weather proof. Mounting hardware included.
Specifications.
Input Voltage: Multi volt 10-30V DC ( will work on all 12v and 24v applications).
Power Consumption: 51W (3W*17pcs High Intensity Epistar LEDs).
Lumen Flux: 3700LM +/-300.
Color Temperature: 6000K.
Beam Pattern: Spot.
Beam Angle: 30°.
Life span: 30,000+ hours.
Dimensions: 7"x3. 5" (18x9cm. )
Mounting bracket 1" tall.
Housing Material: Die-cast Aluminum Housing.
Housing Color: Black.
Mounting Bracket: Die-cast Aluminum.
Electronics: Integrated-Epoxy Encapsulated.
Extremely bright, not DOT approved, offroad use only.
Specifications.
Beam Pattern: Spot.
Beam Angle: 30°.
