bzerko_cj7
- Feb 15, 2006
- Vass, NC
OK, so I bought Yager’s old Jeep some time back. It’s got a TBI 307 SBC, 700R4, Dana300, D60 & 14B, and 42” tires. He had no issues with stock transmission when he had it. It had 38” tires at that time. When I bought it, he had the transfer case out to replace the output shaft with a heavy duty shaft. So I figured while the t-case was out I would get the tranny beefed up a little.
Upon a referral from a friend, I had a “mechanic” rebuild it in the garage at his home (may have been first mistake, dunno). It’s got Raybestos clutches, Atlantic torque converter, TCI manual valve body, Corvette servo, Beast sun shell, etc., about $1,000 for the rebuild.
Anyway, get it put back together and everything seems to work fine on trails, slow speed, etc…but occasionally I will drive it on the road. If you get up any speed, the tranny temp climbs rapidly, especially if it shifts into overdrive. Maxed out the gauge a couple times.
The TCI kit came with a vacuum switch for the lock-up. Tried it with it hooked up, unhooked, adjusted the vacuum setting, etc…no help.
Took the vacuum switch off and wired a direct toggle switch to lock-up…no help.
Did a bunch of research on the TV cable adjustment. Got adjusted where I thought it should be…no help.
Added a Hughes aluminum oil pan and a 30,000 lb Deralle external cooler with shroud and own cooling fan, mounted behind radiator…no help.
I’ve talked to several local transmission shops and most don’t seem to know a whole lot about the 700R4 with lock-up converter. They just want me to bring it in and let them tear it apart to check it out. I have talked to all kinds of people…TCI tech support, drag racers, offroaders, gear heads, etc…no solutions.
I have changed the fluid so many times I probaly could have bought a new tranny by now with the cost of fluid these days.
I don’t know, maybe the guy who rebuilt it has something screwed up. Maybe wrong torque converter. I keep thinking it is something to do with the lock-up converter, but can’t figure anything out. I am at the end of the rope with this thing. If anybody has any ideas, it would be appreciated.
I really don’t want to have to spend the cash to have it rebuilt again as it only has a couple hundred miles on it. If anybody knows of someone who REALLY knows something about 700r4’s and lock-up converters, I may consider having it rebuilt once again.
