For one in Winston that does know, contact Brian at the Shell station on the north end of Reynolda, right across the street from Linebach Machinery. At least he use to work there.
It's Old Town Shell and Brian was there last week when i had some tires swapped... talked to him & Bobby for a bit while I waited. OTOH, he seems to be taking Brent's route and taking forever to get his junk built!
What's wrong with your 304? Not running good or blowing/burning/using oil? Or something else? Not sure where in W-S you are, but if you like a second opinion on your motor, LMK! (I'm out Reynolda near Bethania)
I was in the same position 6 years ago... 304 was worn slap out (1qt. of motor oil for every 30 miles or 30 minutes running = rotated the plugs in a couple cylinders as they fowled). As dropping a 360 in *would* have been cheap(er) and more power, finding a flexplate my TH400 (QT crap won't fit) was a pain. I ended up buying a fairly fresh rebuilt 304 from a bud of Spraypaintdude (back when Noah had a real Jeep
) for $400. Put in some seals & gaskets before dropping it in... ^^Brent^^ & Patrick (RIP) came out to Mocksville (uncles shop with 2post lift) and gave me hand with it.
Had some issues over the years (burnt valve seats = induction harden from the factory) and the usual oil leaks, but it continues to run pretty strong after some stout abuse. While the 2100 continues to be the simplest/best running carb there is short of FI, I'd love to drop a homegrown FI in the Moss just for S&Gs.
If I had to do over again (I'm NOT a "puriest"), I'd likely NOT go the SBC route, but drop in either a 4.xL stroker or 4L HO with FI...
