Buddy Holly
Professional Amateur
- Apr 6, 2014
- North Raleigh
I am currently swapping an 8.8 into the rear of my yj without an SYE. I had the pinion angle set to about 1 degree higher than what the Dana 35 was at, to accommodate for the lift the jeep has (sagging 2" springs, about 1" over stock SUA). The angle is now about 3 degrees. The issue I am having is with the driveshaft binding at full droop. The ears of the DS physically are hitting the flange adapter. The only way I was able to get it to not bind is by installing 6.5 degree pinion shims under the springs (something I am extremely hesitant to run). Even with the shims there is less than 3/8" between the DS and flange adapter. I am planning on buying an SYE when I get the money saved up. I didn't plan on doing the swap without it, but the 35 was worn out and about to blow the R&P so something needed to be done ASAP.
Any ideas on this? The 35 never bound up like the 8.8 does and it was an even shallower pinion angle. I am fairly certain the binding is because of the flange/flange adapter of the 8.8. Is there a flange adapter that has better clearance? Would a conventional yoke give me more clearance?
