- Mar 10, 2005
- Hooterville (24171)
I've got an 8.8 in the Mustang with 165k+ miles that's beginning to leak pretty badly from the pinion seal. It had a small leak (no measurable fluid loss, other than the "wet spot"), but has progressed over the past year. When I serviced it last year (7-8K ago), the seal was intact, but there seemed to be a very slight "wiggle" (axially) at the pinion flange. I hit it with an impact to make sure the nut wasn't grossly loose (wasn't), so topped it off.
While I know the seal can be changed, are the pinion (& carrier?) bearings pooched now due to the mileage? I suspect the pinion "egged" the seal and is causing the leak.
What should I expect?
Partial rebuild? (pinion bearings & seal + axle seals)
Complete rebuild? (all that + carrier bearings, etc)
I know I can find some decent (lower mileage/rebuilds) takeout 8.8's, but they're most likely going to be 3.55s, where my auto geared 8.8 is 3.27 and I like the few 100rpm difference at highway speed
