lagnaf311 said:I have a 1998 TJ, and I am planning on switching the rear 35 for an 8.8. I woundering just how much work would be involved in this switch. I am also interested to know the pros and cons of the 8.8.
Wolfpack OffRoad said:The shortcomings of the axle are easily overcome: weld the tubes to the housing, throw a detroit in to eliminate the carrier problem, and if you break a shaft the calipers should keep the shaft in so you can limp back home.
COT: Continuous output torque rating
MOT: Maximum output torque rating
Numbers from January edition of Fourwheeler, page 60.
Dana 35 rear axle COT: 870 MOT: 3480
Dana 44 rear axle COT: 1100 MOT: 4460
Ford 8.8 28spline COT: 1250 MOT: 4600
Ford 8.8 31spline COT: 1360 MOT: 5100
Dana60 semifloat COT: 1500 MOT: 5500
