8.8 yoke adapter
Olivers drive shafts in winston. Took them an explorer shaft and my shaft and presto!
You can take that explorer rear drive shaft apart at the axle end ujoint and use the flange that bolts on the yoke, go to Napa and get a conversion ujoint 1310-1330 and put it on your rear yj shaft and bolt it on. That's what I did and been beating mine for a while. It seems to be a lot stronger than the straps jeeps have stock.
Also. Are ya'll moving the spring perches on the axle, or just tightening them down on the ones on the axle aready? Think the spring centers will be 5/8 wider on each side
you should mover the perches to match up with the spring centers.
