Any ideas about running a locker and using the vacuum disconnect manually like having a selectable locker? Like in the stock YJ and TJ axles w vacuum lock. I was planning on somewhere in the 37" range for trail tires. I know that in my 97 dodge the front end will hop significantly when 4wd is engaged, much like the locked front end in my CJ. I mean it binds and jumps, no slip or skip in the axle itself and that is a 10,000lb rig.
