80 toyota needs power steering
cheapcherokee89
oxford
i got a 1980 toyota pickup with the 20r in desperate need of power steering, did not come factory. are there any kits to add it? if not what year steering box , resevoir etc. would be the best to add it
Best bet...
Do x-over steering and add a p.s. pump from another Toyota Truck.
Unless you've got a lift the cross over steering won't work. It will hit the oil pan. I'm not sure if the power steering from the 22r will bolt up. You'll also need the extra pulley for the crank. The second on that is existing is for A/C so if you don't have a/c you'll have a vacant pulley between your belts.
