84 Scrambler and Trailer(combo package :-)) - $25,000 obo - Raleigh, NC
brp083085
Raleigh, NC
Life is pulling me in different directions and I’ve decided to sell my 84 Scrambler. I've owned this jeep since 2019. I purchased it from an active duty Navy sailor who bought it in California, shipped it to Oaho, Hawaii, then shipped it to Virginia Beach when he was restationed in 2018. When purchased, it was not in the best of conditions… the engine was in need of an overhaul, it had manual brakes and to be honest, was a terror to drive. I swapped in a Dana 44 rear built by East Coast Gear Supply in 2020 and slapped a pair of 35's on it. My friend and former fabricator for Hendrick Motorsports and owner of Deerfield Fabrication, built the rear spare tire carrier and the roll cage. The cage was built off of a GenRight LJ cage design and Brian was able to bend and weld the cage together, as he would for Nascar teams. In 2023 I purchased the current set of axles that are under it and brought it to its current condition. Once adding the PSC hydro assist steering, as well as the other upgrades, I can drive it down the highway at 70mph and steer it with 1 finger. It has 0 wonder when driving and is an all-around pleasure to drive either to work, going to get ice cream or on the trails.
Also for sale to go along with my Jeep is an 18ft Hurst Equipment Trailer. Trailer dimensions are 18'x83". The GVWR is 12,000lbs. The trailer has brand new tires and wheels with less than 500 miles. The axles and bearings are serviced yearly, most recently in May 2026. The deck is in good condition and is coated with deckover to ward off excessive corrosion on the boards. I am selling both of these as a package and would prefer not to separate. Serious inquiries only and no joy rides. I'm sure i'm forgetting something, but if interested, please reach out to me and let's talk!
Willing to deliver within reason or a fee for longer trips.
Drivetrain:
- Engine - 1994 Jeep XJ 4.0 - Mileage unknown
- Body has around 170k - I have put ~20,000 miles on the Jeep since purchasing in 2019
- New water pump
- Custom ignition and wiring harness by Eli Fixes Jeeps(2024)
- Powermaster PowerMax starter
- Holley Terminator X MPFI
- Full Painless wiring harness by Eli Fixes Jeeps(2024)
- Holley Hyperspark 2 distributor
- Holley Hyperspark ignition coil
- M.O.R.E motor mounts
- 20 gallon poly tank
- Custom Exhaust with magnaflow muffler
- Jeep TJ intake manifold with 62mm throttle body
Transmission
- original T5 - Rebuilt by PO
- Shifts smooth, no issues
- Novak hydraulic clutch conversion
- B&M short shifter
Transfer Case
- Dana 300 - Rebuilt in 2024 with LoMax 4:1 - Twin stick
Driveshafts
- Adams Driveshaft - Front & Rear - 1310 u-joints
Axles
- Front Axle - GM dana 44(Installed by Independent4x 2023)
- 456 gearing - 63" WMS
- 30 spline RCV axles inner and outer
- Yukon hardcore locking hubs
- ARB air Locker
- One ton GM steering
- PSC hydro assist
- Rear Axle - GM dana 60(Installed by Independent 4x 2023)
- 456 gearing - 61" WMS
- 1" spacer on each side to get width to 63"
- 35 spline Dutchman chromoly axles(new - January 2026) - With spare set
- ARB air locker
- Chevy K10 calipers front/rear
Wheels and Tires
- 5 37x12.50r17 Cooper STT Pro - ~1000 miles - New spare
- Raceline Monster full beadlocks
- 17x8.5"
Suspension:
- Rubicon Express 1.5" spring over
- Bilstein 5100 shocks
- M.O.R.E 1/2" shackles
- Daystar 1" body lift
- Anti-wrap bar
- Ford Style shock towers
- Currie Anti-Rock
- Polyurethane bump stops
- PSC Hydro assist steering with PSC gearbox with assist ports, HD pump and remote reservoir
- Borgeson steering shaft with Wolff Engineering column bearing
- M.O.R.E HD Steering box mount
- M.O.R.E Steering brace
- Frame reinforcement plates by Jason Adams(CHIEFWAHO on CJ-8 forum)
Body:
- Patina brown
- Original dash and dash pad
- YJ steel lower doors with TJ uppers
- Full BesTop supertop - A couple teeth on the zipper on the rear drivers side are broken off, but still zips full
- Durabak bed liner
- Poison Spyder Customs full rear corners
- Poison Spyder Customs rocker guards
- Genright aluminum rear fender flares
- Genright aluminum front fenders and flares
- Taboo Customs oil pan skid plate
- Full custom 6pt roll cage built by Deerfield Fabrication- Tied into frame - Brian Sorrell(owner) former Hendrick Motorsports fabricator- Have detailed pictures of the cage build if requested
- Bid Daddy Offroad rear bumper with custom swing out spare tire carrier built by Deerfield Fabrication(Brian Sorrell)
- Warn front bumper
- Warn XD9i winch
Other:
- ARB twin stage motor onboard 12v air compressor
- Speedhut gauges
- Corbeau seats with harness
- Tuffy center console with Sony Bluetooth stereo
- Kicker dual speaker pod- Midland GMRS radio
- Rear Tuffy cargo storage
- ARB premium recovery kit
- Spiderwebshade sun shade
- Grant wood steering wheel
- Optima yellow top battery(2025)
- High-beam offroad LED headlights
- Quadratec LED tail lights
- power brake booster
Notables:- Frame is in excellent condition with zero rust
- Body is in great condition with one rust spot(see below)
- Small rust under b pilar on drivers side
- Has been treated and is covered up by cage pilar plate
- Damage has not progressed since owning Jeep
- Extremely small drip from rear main seal
  • att._bW0KNwKi0u1oOb9vr8U5l3hJr5TexFIY60dqcwSm5U.mp4
    6.6 MB
