85 cherokee with no fire
K5MAN
Wallburg NC
my son has a 85 cherokee with a 2.5 4 cylinder we just rebuilt the engine and now it won't fire but once when you let the switch go any ideas.
Sounds like you are losing your 12v to the coil when your key switch is in the crank position. Make sure that if this is something that is wired differently from Stock that the wire is hot at alltimes when the key is in any posistion except off.
Ok I have checked the switch and it checks good replaced the coil replaced the pick up in the dist. and had the ignition mod checked and it checks good but still no fire while cranking and one spark when the switch returns to the on position.
This thing is driving me crazy!!!!
Anyone had this happen before????? if so what was it HELP PLEASE!!!!!!!
