85 toyota break line routing
85yoder
oakboro NC
whats the best way to run the rear break lines on a toyota that is truggied and 4 linked in the back any suggestions is welcome ive seen both hard lines mounted to the top link or steel braided lines what is yalls oppion?
Stock they had one flex line that tee'd on the axle and went to both wheel cylinders. Mine is a stainless steel flex line from Trail Gear to accommodate for lift.
I'd run a flex line to the the center if the axle and then to both sides. Have seen flex line ran done the upper link before as well.
Sent from my smart box using Tapatalk
In the rear you can do away with the load sensing proportioning valve, a stock rubber line from a 90-94 300zx has the same fittings and is a good bit longer than the toyota rubber line.
