Subzilla
Test Driver
- Jun 13, 2011
Added 2" BDS lift to the mall crawling K5 and had some unstable steering. It's not really bumpsteer, just won't hold a straight line down the road and just seems weird ever since the lift. Replaced the worn out draglink, snugged up the steering box (sector shaft had some minor play) and have checked the other tie rod connections. Ball joints are not too old. I added the ORD steering box brace kit 10 years ago and have checked for cracked frame here. I kept the factory steering arm which makes the drag link angle quite excessive in my opinion - especially when you max out the steering wheel - the pitman arm rotates further up making the drag link angle worse. Everything I read says the drag link should be level to the ground AND that a steering correction is not needed until you get to a 4" lift. I'm thinking I need to make this angle better with a raised steering arm. Any thoughts?
