88 4 runner overheating
jimisouljah
Active Member
Kannapolis
I just finished changing out the lower radiator hose on my 88 toy 4runner...drained all the antifreeze and refilled. Problem is now it's overheating! Sometimes it runs hot when you first start it up, but once it gets to about 3/4 on the temp guage it goes back down to about a 1/3.
Any sugestions?
My suspicion is that you had some crap that broke loose in teh process, and is now plugging the stat.
Personally, I'm a fan of the old style stats that have the bypass valve; you have to specifically ask for them at the parts department, they won't know by default.
http://www.4crawler.com/4x4/CheapTricks/index.shtml#Thermostat
one question, IS your runner a 3.0L? If so I had the exact same problem a few years ago on my 88', I did the exact same things you speak of here. Honestly, unless you see little floaties hanging out in the coolant when you take the cap off, i doubt its a blockage. I went through the same line of progression then. My guess is that its an air bubble in the system. It will cause your gauge to read funny and the engine to heat. The solution is that you have to "burp" the system. There are a couple ways to try this. The simplest is to leave the cap off and let the engine run at idle (sometimes i kind of repeatedly squeeze the upper hose to attempt to force air bubbles out). If that dosent work, I have taken the highest coolant hose you can find loose and run the engine till you get flow there (run with the heat on high always). Also find a way to have a catch vessel for the coolant run off (may have to couple a piece of heater hose on to it what ever). I had to use the second method to get mine to "burp", after that no more problems ever (coolant wise). Hope that helps, might be something to try before you spend any more money. These may not be the only ways to burp the system, I am not a mechanic so... maybe others will chime in with their method.
Good Luck - J
Ha! yeah if all else fails pat it on the back till you hear the burp. Do you have rear heat out of the center console? If so i could see that as a potential place for air to hide... running the heat should push it through though.
