Trailmaster C
- Mar 30, 2005
- Roxboro N.C.
Ok so I drive the burb to work wed and go to get fuel and notice there is something leaking on the ground on the drivers side of the engine i drive it home, Dark can't see a thing! I go to Ck it out today and can't tell where it is comming from I felt around the intake to head area and didn't feel like it was comming from there but it was a steady stream running down under the burb???? There is a tube that goes from the manifold on one side to the other side never seen this before does it have water(ANTIFREEZE) In that line?they both go into the manifold at the front of the engine and runs behind the engine I think that might be the leak but just can't tell ??? what does that do heat the exhaust??? Any ideas????
Thanks,
Bradley C
Thanks,
Bradley C
