be glad to help man. that renix model can be annoying to diagnose. the tps is adjustable and can cause that, the ground circuit for the tps should be checked and add an extra ground wire to that circuit, as other guy said check your basics first but if that doesn't solve start looking at the two mentioned above. adjusting tps on Renix jeeps is huge importance and lots of connections have corrosion in that big black connector at the firewall above master cylinder which cause voltage drops and grounding issues for harness running to tps. theres a whole thread for that connector issues but take it out and clean it real good with brake parts cleaner and then electric spray along with the ground strap at the back of the head, and then check ground voltage on the ground wire to tps. very common problems on the 87-89 XJ renix which I've owned 9 of them so been there, done that with tons of hours of figuring and researching. hope this helps, let me know if you need more direction. happy wrenchin!
