88 XJ Transfer Case Problem
2000F150SAS
Fuquay-Varina, NC
88 XJ. When the transfer case is in 2 high the part-time light is on, and the front driveshaft is turning. What is problem; it’s a manual shift transfer case, right?
Thanks
If its got the D30 the axles are hooked to the wheels all the time and spins R/P and therefore spinning the drive shaft even in 2WD. Just saw the year of said jeep, so its probably the vac disco on the long side shaft just hung up or something.
So is the transfer case spinning and draining power like it was in 4x4? Or is it just spinning free and not sucking power?
Make any sense?
Thanks
Since the DS is spinning it's still in 2h and until i shift into 4l or 4h then i'm in 4x4?
Thanks for the help
vac on axle was just replaced with a posi-lock conversion
We have the posi-lock with out the cable, so the 2 axles become one.
