IIRC?Yea IIRC there is a fuse for the computer. Check that like said. If all fuses and TPS check ok then I'd look at the computer.
if i remember correctlyIIRC?
I know you said you checked the fuses...was that just the standard fuses or underhood fuses? There is a TCU fuse under the passenger side dash somewhere between the TCU and shifter. It really sounds like the TCU isn't coming into play here. Does it behave the same with the computer unplugged?
not exactly sure what you mean by not coming into play. I have read a little bit about the wiring, there is two verified 12v power sources at the tcu. Where can I get the schematics for the tranny? TPS is set properly, IM READY TO BURN IT! Thank you guys for the help.I know you said you checked the fuses...was that just the standard fuses or underhood fuses? There is a TCU fuse under the passenger side dash somewhere between the TCU and shifter. It really sounds like the TCU isn't coming into play here. Does it behave the same with the computer unplugged?
it just sounds to me like the TCU isn't doing its job somehow, could be wiring issue, internal TCU, dunno. If disconnecting the TCU doesn't change anything, there's something wrong.not exactly sure what you mean by not coming into play. I have read a little bit about the wiring, there is two verified 12v power sources at the tcu. Where can I get the schematics for the tranny? TPS is set properly, IM READY TO BURN IT! Thank you guys for the help.
I think if you can shift if manually the selinoids are working. I'm not sure if yours is the same but my 94 takes it speed sensing data from a separate speed sensor on rear of the tranny not the one on the trasfercase.How do I test the speed sensor and the selinoids?
Thanks for your help. Still plugging away at the problem.
