89 - 85 Yota Rear Third Member swap
j28vb
Mebane, NC
Hey guys, I am new to the forum and love all the info I have read so far. I now have a question for you experts.
Does anyone know if an 85 Yota truck rear third member will fit an 89 V6 4-runner Axle without any modifications?
Thank you,
Jason
Are both from the rear of a 4x4 ?
If so the answer is yes, it is a direct bolt in. BUT make sure the gear ratios are the same. Otherwise you will have lots of problems. The V-6 rear is actually better because the carrier bearings are larger and stronger.
yes they are both for the rear. I am only swapping the third members while I build up the V6 third. I need to drive the truck on the road while i build up with 5.29's and can save up for an ARB locker.
Thanks for the input.
Jason
You'll be fine to do that for sure.
