9" bearing retainer
biggoofy
Utah Jeeper
SLC, UT
WTF is it actually called I cant find any info on them other than you have to cut them off well I need 2 new ones for my new shafts and cant figure out how to order them
But what's the damn thing called!
I think it's just called a wheel bearing retainer. If its like Toyotas it should come with a new one when you get wheel bearings.
Sent from my mobile Toyota base using Tapatalk
Will do thanks a bunch guys.
You talking about the flat plate that bolts up againist the backing plates? Just press the bearings off your old shafts and youre good to go.
No the big metal piece in front of the bearing.
The lock ring? Pressed on right after the bearing?
Thanks.
