RRADFORD9ER
- Dec 3, 2006
- Asheville
I'm in the process of building up a 9" to swap into the WJ and need a little help determining which parts I need to finish it up. I've got big bearing late style housing ends and the explorer 8.8 disc brake setup. The bolt holes for the brakes are about .15" off when compared to the housing ends, so I'm going to grind the holes out a little to make it fit. I read that you need to get these Bearing Retainer Plates from Currie. But when I was on their site I saw these Spacer Rings too. Do I need both?
Thanks for the help
Thanks for the help
