Supposedly the 8.8 discs brakes bolt up to certain ford 9 models...Didn't work for me though. I ended up fitting the brakes from my Grand Cherokee with a little fab.
lincoln hat roters. dana 44 Ford calipers and brackets from a front. two small flat steel adapter brackets. the calipers are the style that uses the the drive in elongated u shape spring. the roter slide right over the axle studs with a little turning on the lathe of the flange. the caliper bracket was modified by remove part of the bolt circle for the spindle. A flat steel spacer adapter bolts the mount to the axle flange that used to locate the dust sheild (drum brake housing).
