Wladziu
- May 1, 2011
- Burlington
Hello. I'm new here.
Years ago, I built up a CJ-7 and gave it to my Dad for fishing on the sandbars of the Outer Banks.
New engine, a fuel injection kit, new wiring harness, 4.5" RE lift (very,very nice with the YJ springs), new 35" MTRs, new cooling system, new roll cage, seats, you name it.
He never drives it.
Go figure.
Anyway....I'd like to address an issue with the Ford 9" rear. The pinion angle is too high, probably. He has no idea what angle it's at, and I'm at the other end of the state.
He says it gets very hot when he does drive it. Hot enough to smell after about 10 miles. I'll probably try to shim it back down as much as I can. I hope I'll be able to retain a reasonable driveshaft angle. It is currently running a double cardon shaft that I stole from a Cherokee or something (can't remember), and a 1" t-case drop. I tried to overfill it some, with 90 wt and a friction modifier. It only has a limited slip, but not sure of the make.
My question is whether I should continue to trust this axle for any type of highway driving or commuting. Can't afford a Hi9.
Does anyone here have experience with the Ford 9"? Is it typical for them to do this, even at correct pinion angles? I know they have oil feed issues to the pinion bearing at angles, but am I sitting on a time bomb?
I towed it from Greensboro to Greenville without a problem....but that's being towed. No torque through the driveshaft, since I removed it.
Thanks!
If it does work out...I'd love to join the Triad club!
If not...anybody need a Jeep?
He never drives it.
Go figure.
Thanks!
