STEVIERAYCJ
- Jan 14, 2007
- EDGEWATER,MD
converting from drum to disc , any advice on this . whats good whats not ? i would like to keep a parking brake due to the at. thanks
some of the 9" were 5on4.5 but most were 5on5.5, which is what hes got, i think...
you should use some F150 or bronco front rotors, or maybe even CJ from rotors, with eldorado rear calipers...
I think there are some cheaper calipers you could use like a camaro, etc. that I cant remember right now...
I used F150 rotors and 1/2 ton chevy calipers
depends on whether you have big bearing early, big bearing late, or small bearing ends on the housing
http://www.wilwood.com/BrakeKits/Pages/11/FLANGE-DIAGRAM001.jpgHave any more info on this? I know I have a big bearing 9, but how do I tell if its early or late?
What did you use for the caliper mount?
that is why you get a mechanical one, I got mine from spydertraxwatch out though, if you leave line-locks on for a week or more it can run your battery down...
